Ouch! My Centerline Wheels got hurt (PICS)
I hate the Mets
Tell me this doesn't suck! Damn construction....Damn manhole covers... Hopefully Wheel Collision can fix it. Luckily my ride is not affected but I know I don't want to drive around too much w/ a screwed up wheel...
1. From a Distance
2. Closeup of wheel
3. And the F'n thing has a hairline crack on the lip now
1. From a Distance
2. Closeup of wheel
4th Gear
where did you get the cl-s door sills, and how do the 18" rims affect the respons and pick up, im debating on getting 19" rims for they might slow me down at the line.
get back at me about the door sills @ 2mandojr@cox.net
2003 acura cl-s
2003 acura cl-s
I hate the Mets
I hit a raised manhole cover on a road being repaved. It is a mystery to me how I managed to screw up the wheel and not blow out the tire, maybe my pressure needs to be checked
I got the door sills through a GB here, the 18" wheels effect ride quality slightly on bumps - I cant tell a difference on normal roads.
Response seems the same if not better, the wheels only weigh a tad over 14 pounds
I hate the Mets
Originally posted by NSXNEXT
Wheel collision can fix that no problem. No worries.
I hate the Mets
Yeah they are forged but I caught the lip of the rim ....
The ride is fine so I am just going to have wheel collision fix it - It will only cost half as much if I have it repaired, and supposedly they do really really good work
that sucks. hopefully they can fix it.
must have been a hell of an impact. make sure to keep your tire pressure ~35psi.
PACDAT
Ouch.. well look on the bright side , at least your rim is still in once piece, Unlike my cracked one. good luck with the repair though.
I fukkin hate potholes, and theyre hard to spot.
that's right
that sucks man.
got a question: i just put 18"s on mine. the steering starts to shake slightly starting at 70km/h. the guys checked the balancing again and said it was fine. they say i need adjusting rings. they also want me to get wheel alignment done too. it the alignment required? n' is the ring gonna fix the problem?
TLDude876
12-28-2016 03:18 PM
nanos
11-12-2015 08:41 PM
merc009
10-03-2015 12:59 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
