No hubcentric ring? RH Evo C2
Originally Posted by notorious7182002
hey, i also purchased rh evo c2s today used. by hubcentric rings do you mean the center caps?
The go on the inside of wheel and you don't see them.
The only reason you would need the rings is if the center hub of the wheel is larger than the hub on your vehicle, they help alot....they may look cheap and look like crap, being a small peice of plasitc or aluminum, but they work. You typically dont need them when they are made specifically for the vehicle like with custom forged wheels.
Any decent wheel/tire shop should be able to take the measurements for you, and if you need them, they can get them for you.
If nobody local has em, check out 1010 tires
1010 Tires Hub Rings
They've got plastic ones, you just need to make sure they are the right size.
For those who have RH C2 5X114.3 rims and want to get hub rings, the outer bore size is 73MM (and of course, the Acura CL's bore is 64.10MM).
Below is the address and telephone number to Dazz sports who makes RH rims (apparently they also support Racing Hart, Lowhart, etc. etc.):
1350 Moutain View Circle
Azusa, CA 91702
(626)962-0033
I think this should be helpful to someone.
Azusa, CA 91702
(626)962-0033
