New Wheels
Old Mar 31, 2011 | 11:07 AM
bcart180's Avatar
New Wheels
Just picked these up today. Petrol Vengeance.
18x8 +40
This is what I was running... I bent one of the wheels so I decided to start over.
Old Mar 31, 2011 | 11:30 AM
AustinTaper's Avatar
Registered Member
looks good man, what suspension setup are you running?
Old Mar 31, 2011 | 11:50 AM
bcart180's Avatar
Tein SS + Ingalls camber kits front and rear.
Old Mar 31, 2011 | 06:52 PM
AARONSredTYPE-S's Avatar
i like the look of the flush and bronze on the other wheels, but the new ones still look good.
225/40 tires?
almost looks like you could have went with a 35et offset in the back. Why do they look so sunk in i wonder?
Old Mar 31, 2011 | 09:10 PM
bcart180's Avatar
I'm not sure. I was thinking that +40 would be close to flush all around. Right now there is slight rubbing in the rear -- but I am getting my rear fenders rolled tomorrow (and an aftermarket cat installed).
I'm also thinking that a 5mm spacer would look good in the rears too. What do you think?
Old Apr 1, 2011 | 01:09 PM
for sure on the spacer.
what size tires are you running?
Old Apr 1, 2011 | 01:10 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Wheels look nice.
Old Apr 1, 2011 | 01:57 PM
civicdrivr's Avatar
You can run a 5mm spacer and it will be flush. My 19x8.5" +40mm were flush, and thats the equivalent of an 8" wide wheel with an approximately +34mm offset.
Old Apr 3, 2011 | 03:29 PM
bcart180's Avatar
225 40s
Old Apr 6, 2011 | 10:08 AM
ID SAY RUN A SPACER THEN. You could without rubbing with those tires
Old Apr 11, 2011 | 06:23 PM
loweredCL's Avatar
I'm looking at adding a wider tire but not sure if they will fit without rubbing. I now have 215/45 R17's and looking at some Michelin Pilots 245/40's but think they might be too wide in the back. I believe my offset is 42. What do you guys think??
Old Jun 3, 2011 | 03:51 PM
bcart180's Avatar
I added 5mm H&R spacers and now the rears are flush. When I had the CL up on the lift I noticed that the previous owner shaved most of the material off of the fenders -- so much for having them rolled. I also took a grinder to the bumper tabs
Old Jun 3, 2011 | 05:06 PM
now that is good right there..
Old Jun 4, 2011 | 08:08 AM
bcart180's Avatar
What do you think about another 5mm spacer up front?
Old Jul 28, 2011 | 09:07 PM
bcart180's Avatar
What do you guys think: I have the itch for the same style of wheel but in 9.5"+35mm only for the rears. I'll most likely use the same tires I have now for a stretch -- 225/40. I know that staggered is not functional (I'm over that) but I want the look.
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
JByron
Jan 8, 2016 09:49 PM
GhostTL09
Sep 19, 2015 01:57 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
