"Never seen before" offset question !
Hi guys, I've been reading some posts about wheel offset and I'd like ask something nobody's ever asked.... Let's say I have a 7½ inches wide rim, 55mm offset with a 215 tires (exactly like stock except for wider rim). The side of the tire would still be at the same place right ? (now concentrate !!) Soooo, does that mean that an 8 inches wide rim with 45mm offset and a 235 tire is not worst (rubbing wise) than a 7inches wide rim with 45mm offset and 235 tire (even if it is not possible)? What I'm saying is the rim will never rub on the fender , it's the tire width and rim offset that matters most with rubbing issues......
AM I RIGHT ???????
By the way what do you think about these. I like the "agressive" spoke:
http://www.discounttire.com/dtc/find...ZDINT&pc=57477
I'm currently looking for a set of wheels for my 235/40/18 P Zero Nero. Problem is: offset 40mm + H&R sport drop = ???
AM I RIGHT ???????
Originally Posted by banana
...an 8 inches wide rim with 45mm offset and a 235 tire is not worst (rubbing wise) than a 7inches wide rim with 45mm offset and 235 tire (even if it is not possible)? What I'm saying is the rim will never rub on the fender , it's the tire width and rim offset that matters most with rubbing issues......
AM I RIGHT ???????
AM I RIGHT ???????
For example, the difference between having a 235 tire on a 18 inch or a 19 inch rim is much bigger than the difference between having a 225 or 235 tire on there. Am I explaining this well enough?
The point is that rim diameter has a much larger effect on how close the wheel setup will come to the inside of the wheel well than the width of the tire alone.Another example... if you have a rim that is 18x8, the offset you choose will have a much bigger impact. In other words, choosing between a +40mm offset and a +50mm offset will have a much bigger impact on rubbing issues than choosing between a 225 tire and a 235 tire (even though the difference in both cases is 10mm).
Now... to answer you first question about the difference between having a 235 tire on a 8 inch wide rim or a 7 inch wide rim.... it's not the same. Tires are made of rubber, and squeezing a 235 tire onto a 7 inch wide rim causes the tire sidewall to have to roll a little bit to fit, at least moreso than on and 8 inch wide rim. Meaning that the tire won't exactly be 235mm wide once you put it on the 7 inch wide rim. Whereas on an 8 inch wide rim, the tire will sit closer to the way it was before it was put on the rim in the first place. For reference, 235mm = roughly 9.25 inches, now imagine the difference in what happens to a tire when you squeeze the sidewalls a half inch further on each side. Granted the difference is not a big one, but it does not stay the same regardless of the width of the rim.
Clear as mud???
And I'm pretty sure that an H&R Sport drop with 18's and a 40mm offset will rub.
I'm right in theory, but not in practice....because of the deformation of the tire depending on the rim width.
But when you say that a 225 tire vs a 235 gives 10mm of width, you're right but thats 5mm per side, not 10 (like a 50mm offset vs a 40mm offset which push the wheel 10mm towards the outside).
Anyway, I'm sure you already knew that but I just wanted to push this thread to the top !
we've taken care of that, click the link, anything with a 50mm offset is perfect for the CL, even the 19" with 235/35/19 tires or the 18" with 235/40/18 tires, you won't rub even with a Slammed ride.
Sizes: 5x114.3
-17”x 7.0” +50mm 64.1 centerbore*
-18”x 7.5” +50mm 64.1 centerbore*
-19”x 7.5” +50mm 64.1 centerbore*
* Hubcentric application
http://ronjonwheels.com/inspyre.html
http://ronjonwheels.com/servo.html
Sizes: 5x114.3
"The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10"." A quote from Tire Rack.
http://www.tirerack.com/tires/tirete...#rimwidthrange
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
