Need a picture of the passenger side suspenson of a 2gen CL please
The mechanic that installed my springs & struts put the passenger side back together with the outer boot touching the shock fork (I am guessing that is what it is called, it's the part that bolts to the strut and attaches everything to the lower control arm)
I know 100% this is what happened because he replaced both boots & 20 miles later the outer boot is destroyed.
I tried to get a printout of the parts catalog but had to go to Honda to get it as the Acura dealer was out of stock but at least gave me the Honda part # since Honda acts like it is a Toyota when I ask for parts.
I am hoping for a picture of the correct orientation so he can get it right the THIRD TIME
Hard to believe this boot has less than 50 miles on it.
This is the axle & shock before they went back in. From the DIY it seems he did not need to remove the axle.
I'll be showing him this picture if he tries to say the boot was damaged when he installed the suspension.
Thanks Allout that is what I needed to know.
The fork was on right, (there was a flat spot on the shock that mated to a flat spot on the fork) At first he started to say the vendor sent two left shocks because the Koni Sticker was on the inside.
I pointed out the other one was on the inside.
Whats up with RDX owners?
So I am half right?
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
