need help with correct offset
Old May 24, 2005 | 09:41 PM
d98clturbo's Avatar
Old Timer
i am about to purchase some TSW Volcanos http://www.tsw.com/new/productline_passenger.php for my 01cl-s they are 19x8 with a 40 offset (this is the only offset that is offered in this size) i would like to know what kind of problems i can expect to incounter...if i have the roll the fenders i will that is not a problem for me...oh i will be getting tein basics ...i would preffer to have the car slammed if you know what i mean..
please forgive me for all my rediculus questions...i was a 1st gen owner (i knew that car inside and out) http://pg.photos.yahoo.com/ph/d98clt...urbo/my_photos
not the same with this one
oh yea i did search couldnt find what i was looking for
thanks for your help
Old May 25, 2005 | 08:39 AM
fuzzy02CLS's Avatar
They will not fit so forget about it. Get something else. 40 is too low with 8' wide. You would be hitting the suspension, & wouldn't be able to turn.
Old May 25, 2005 | 07:29 PM
d98clturbo's Avatar
Old Timer
what if i put some spacers on the hub (like a 5mm or 7mm spacer)
Old May 25, 2005 | 08:19 PM
NSXNEXT's Avatar
1 - you will not be hitting the suspension, you will be hitting the fender
2 - spacers make the problem worse, they push the wheels farther out of the wheel wells
3 - 19x8 requires a +50 offset to fit without rubbing. You are 10mm to low.
4 - If you plan to slam the car, you will probably want to go with 225/35 series tires to avoid any rubbing.
neuronbob
23
Jul 16, 2019 10:48 AM
ITSJESTER
17
Dec 6, 2018 02:29 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
