Lowering
Old Oct 18, 2004 | 08:58 PM
JaredGMS's Avatar
Meat stick
Lowering
What parameter of lowering dictates whether a camber adjustment is needed or not? Is it how low you go? Also, what does "Rake" mean?
Old Oct 18, 2004 | 09:14 PM
JaredGMS's Avatar
Meat stick
No one knows?
Old Oct 18, 2004 | 09:29 PM
mech's Avatar
You camber will become more negative the lower you go, when you lower more than 1.5 you need check your camber, rake refers to the stance of the car with the front end being lower then the rear
Old Oct 18, 2004 | 09:31 PM
JaredGMS's Avatar
Meat stick
What springs will not go low enough to screw camber?
Old Oct 18, 2004 | 09:45 PM
mech's Avatar
well there is no sure bet but the H & R OEs and Tien S.tech(i think) should still keep the camber in spec, you can try lower
a camber kit will allow you do go with any springs you want, thats like 150
anyway you go, get an alignment after you lower the car and they will tell you what the camber is
Old Oct 18, 2004 | 11:48 PM
JaredGMS's Avatar
Meat stick
THANKS!!
Anyone have a more solid (or possibly complete) answer ?
Old Oct 19, 2004 | 12:00 AM
JaredGMS's Avatar
Meat stick
THANKS!!
Old Oct 19, 2004 | 12:08 AM
azian21485's Avatar
7-30-05 First Place STS!
that IS the complete answer...o.e springs are the safest bet if your very worried about camber
every car is different (not talking about different models..talking about every singe cl is different than every other)..some cars' camber might not be affected that much and stay within specs with a 1 inch drop..and others will be out of specs...it depends on alot of things
when you lower your car you're gonna need an allignment anyways no matter what because your toe will be out of specs (maybe not but most likely) and chew through your tires..you can either do it yourself or have a shop..for you i recommend getting a shop to do it...they will set toe back within specs and then give you a print out of your castor, camber, and toe
then you can decide if you want a camber kit or not
remember camber is not a bad thing
Old Oct 19, 2004 | 12:32 AM
JaredGMS's Avatar
Meat stick
Thanks for the sarcasm, I know that camber is not per se a "bad thing". I was simply curious whether anyone else knew of other brands that may fill my requirements. My point is that I really cannot afford to lower and then drop another $150 for a camber kit. (I have a set of headers, wheels, tires, and icebox to buy!!)
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
