Ingalls Adjustable Ball Joint vs. Ingalls Adjustable Control Arm with Ball Joint
I own a 2001 CL-P and bought RonJon Sport Design Legend Type II wheels (20" x 8.5" with +52 offset) and BFGoodrich g-Force T/A KDW NT tires (225/35ZR20/XL). As for my suspension, I bought a Ksport Kontrol Pro Damper System with custom rear spring weights to help accommodate the weight of my audio system (200 lbs. left/right) and an Eibach Anti-Roll-Kit (both front and rear sway bars). I want to lower my car so there is barely no gap between the tire and the fender. However, I do not want my tires to rub when I hit a bump or take a sharp turn. As for my alignment, I originally bought SPC Adjustable Ball Joints for the front with camber +1.50 ˚ to +3.00 ˚ (http://tiny.cc/n17nx) and SPC Rear Arms with Ball Joints for the rear with camber -2.00 ˚ to +4.00 ˚ (http://tiny.cc/9rp9p). I decided to exchange my SPC alignment kits with Ingalls alignment kits after reading the following: http://tiny.cc/3ool9.
I am going to buy the Ingalls SmartArm Adjustable Link, Camber/Toe, Rubber Bushings for the rear with adjustment range of -1.5 ˚ to +3 ˚ (http://tiny.cc/titjf) BUT I am unsure what I should get for the front. I am debating on whether I should get Ingalls Adjustable Control Arms with Ball Joints with adjustment range of +1˚ to +4˚ (http://tiny.cc/9us3m and http://tiny.cc/fvoua) or just Ingalls Adjustable Ball Joints with adjustment range of +1.5 ˚ to +3 ˚ (http://tiny.cc/zj27l). Which front Ingalls alignment kit is best for my set-up?
From what i understand the ingalls rear is better choice than the spc rears, but for the front they should be about the same for the ball joints. As for whether to get the ingalls balljoints or the arms with the balljoints, it would come down to money and also i have heard the arms give more clearance than the ball joints because the ball joints have the screw/nut on top that can hit the shock tower if you lower car too much.
I was going thru the same decision process and i decided to keep my front spc for now and bought the ingalls rear. If i need to replace the spc front in the future i will get the full ingalls arms. Hope this helps.
3.5 psi
i emailed ingalls about the front ball joints. They are 14mm or so taller than OEM ones and if you're lowered you will likely bang the top fender wall on bigger dips. I'll be getting the full arms for the front soon. They also look to be wayyy easier to install than a ball joint.
Whats up with RDX owners?
Did they tell you how much taller the full arms are? I have them sitting in a box waiting to go in when I feel like it.
How do the Ingalls control arms compare to the OEM ones?
Why do you say that the adjustable control arms with ball joints look easier to install than just the adjustable ball joints?
You have to press out the ball joints compared just unbolting the arms.
They may be a few MM taller. Not nearly as tall as the other ball joints, but there is a hump on it.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I would go with the arms over the ball joints
I have decided to go with the Ingalls Adjustable Control Arms with Ball Joints instead of just the Ingalls Adjustable Ball Joints due to the information from this thread.
There are two adjustment ranges offered for the adjustable control arms with ball joints: -2˚ to +1-1/4˚ camber OR +1˚ to +4˚camber. I believe I should go with the +1˚ to +4˚camber adjustment range for my set-up. Is this correct?
3.5 psi
sounds right. When you lower the car you only get more negative camber. So you'd only want + adjustment. If you're going with no wheel gap you'll probably be more then -1 camber in the front.
Ingalls only offers adjustable control arms WITH ball joints for my car. They make adjustable control arms WITHOUT ball joints, but they are apparently not compatible with my car.
When you say "I would go with the arms" you mean the adjustable control arms WITH ball joints, correct?
That's what I was thinking. Thanks for the clarification!
Lightning Motorsports
Has anyone purchased parts from Lightning Motorsports (http://lightningmotorsports.com/)? They have a "C" rating from the Better Business Bureau. I can buy the Ingalls Adjustable Control Arms with Ball Joints (for both sides) and the Ingalls SmartArm Adjustable Link, Camber/Toe, Rubber Bushings (for both sides) all for only $331.92! From my research, I would spend about twice as mush if I bought the parts from any other company. i.e. It would cost me $645.16 if I bought the parts from Assaultech Performance...
mlody
12-04-2019 02:11 PM
lanechanger
10-13-2015 10:56 AM
