How do you guys think these will fit?
TQ > MPG
19x8"
Front +35mm offset
Rear +38mm offset
Wheels are Axis Mod S7 and 225/35 tires.
My car's a 03 CLS6 with H&R springs. I just dont want them sticking out of the fender or rubbing like crazy. I can trim the fenders for rubbing, but cant really do anything if they stick out too much.
Thoughts?
Front +35mm offset
Rear +38mm offset
Thoughts?
Whats up with RDX owners?
Fronts are pushing it. You will be sticking past the fender.
I dont like insane camber, so my 18x8.5 +43mm wheels are flush with the fender.
1/4 further in (on the outside lip) is negated by the 8mm offset different.
Its definately possible to run them but I dont know what would be required.
You should definately be able to get away with the rears with a fender roll, trimmed bumper tabs and slight camber.
Use a dremmel or anything else with a cutoff wheel and take off the material on the bumper tab so the wheel wont hit it.
acura_dipset_tl
01-01-2016 03:02 PM
wusty23jd
09-24-2015 11:41 AM
