Help: Question on BBK
Old Aug 15, 2005 | 02:04 PM
Rspec's Avatar
I have an 01 CL-P with 18x7.5 axis mod withan +42 offset. No i want to get a Big Brake Kit and i dont think it will fit with my rims and i think some ppl mentioned wheel spaces so my questions are
1. Do wheel spaces hinder performance in any way at all.
2. Do i really need the BBK cos i just got the legend calipers and also got Comptech brake lines that i was going to put on as soon as i got back to ATL.
PS, i drive 120mph daily to exercise my car.
George
Old Aug 15, 2005 | 02:07 PM
Smitty's Avatar
Old Aug 15, 2005 | 02:14 PM
RaviNJCLs's Avatar
I think the Legend Calipers and SS brakelines will be fine. And you should not need spacers with the Mod Se7ens and a 42 offset. In fact spacers will more than likely cause some rubbing with that offset.
Old Aug 15, 2005 | 05:49 PM
NiteQwill's Avatar
Adventurist.
Offset has nothing to do with the use of spacers. The backspacing of a wheel does. You have to insure that the backspacing of the face of the wheel is greater than 2mm or you will run into major problems.
WIth my RJ wheels, the backspacing was about 1.5 without spacers. Feeling uncomfortable, I added 5 mm spacers. Piece of mind....
Old Aug 15, 2005 | 11:28 PM
Pure Adrenaline's Avatar
Dragging knees in
It's not so much the offset, but rather the design of the disk and spokes.
If you are not planning on road racing your car, then you do not need a big brake kit. You will be more than fine with the Legend calipers, SS brake lines, good pads and fluid. You will save hundreds of dollars.
Old Aug 16, 2005 | 02:20 PM
Rspec's Avatar
thanks alot guys i think i will stick with my legend calipers and maybe in a few years when i change my rims i will go with the BBk just to make my car still look hot because those things are cool like on NiteQuill's car.
Old Aug 16, 2005 | 09:19 PM
power3dfx's Avatar
Parting out 02 Type S :(
BBK are for RACE use only! thats the disclaimer that actually came with my calipers. and for good reason. any BBK should be really strong, too strong in my opinion for the street. the problem is that you will not be able to fully utilize the power of a BBK because the roads suck!
if the stock brakes can get us to the limit of grip under heavy braking, you really need a smooth surface to get the full effect of the extra braking force of the BBK calipers. the only good thing about the BBK is less warping and reduced fade. if you havent experienced fading on your brakes currently, then you definately do not need a BBK.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
