Help!!! Problem with springs!!
Bitten.
So, I bought my '04 TL about a month ago. When I bought it, I had them through in some eibach springs. It turns out that the springs are for an '03 accord-which has the same suspension, but is lighter in the rear than the TL.
Anyways, I had the springs installed and it drove fine. It pulled a little to the left, so I had an alignment done. The car was in speck except for the rear camber-no problem, a camber kit is on order. But, after I had it aligned, a problme arose.
When I am driving and am at "idle" (i.e. no aditional gas), the car tracks straight. As soon as I give it any gas, not flooring it all, the car pulls hard to the left. No lights illuminate. The dealer says that it is the springs (because the car is lower in the rear then the front). But, I drove a stock '03 CL-S that had the same problem.
What the heck is wrong????? I need it fixed quick because I am leaving tomorrow on a road trip!!
HELP!!!!
HELP!!!!
Pulls to the left
Hmmm - are your tires like hardcore camber worn? Inside edges rubbed to the belts?
Maybe you have a tie rod end loose / broken?
If your 4 wheel alignment is out - it could cause it to pull bad
Take a laser pointer and run it straight down the car, pointing it at the rear of the car from the front. your inside and outside tire edges should be inline
You might rotate your spare tire onto each of the cars wheels and see if it has any impact - maybe you have one wheel way out of line or yer camber is whacked.
Dunno - just throwing out ideas![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Good luck..
Good luck..
Bitten.
Good luck..
Good luck..
This is why I have absolutley no clue as to what the heck is going on. VERY frustrating.
cycdaniel
12-17-2019 10:58 AM
jmoney2001
08-12-2019 06:23 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
