Headlight issues.
Old Dec 23, 2009 | 08:00 PM
loopey dude's Avatar
Headlight issues.
My wife's 03 cl has moisture in the pass. head lamp. The seal between the lens and housing seems to be gone. Where is the cheapest replacement part available? The color is Anthricite.
Old Dec 23, 2009 | 08:07 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
first of all your posting in the wrong area and as for the head light, the cheapest fix would be to take it apart and re-seal it or tape a silicon packet to the inside on the back of the hid cover, if you really want to buy a new one then google acura of peoria
Old Dec 23, 2009 | 08:15 PM
civicdrivr's Avatar
Dont pay any more then $200 for one headlight.
But, re-sealing it will take $20 at most. Just pull the headlight out and either seperate the lense from the housing and replace the sealant, or if you dont want to seperate them put a bead of silicone around the seam.
Also, check the gaskets on the high beam, lowbeam and underneath the light where the ballast seals it. They can dry up and go bad.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
