Cusco Bars Installed + Eibach Drop
https://acurazine.com/forums/picture...ictureid=27778
https://acurazine.com/forums/picture...ictureid=27780 https://acurazine.com/forums/picture...ictureid=27781 https://acurazine.com/forums/picture...ictureid=27782 https://acurazine.com/forums/picture...ictureid=27783 https://acurazine.com/forums/picture...ictureid=27784 Eibach Pro Kit Drop The Strut Bars work wonders!! Mods, if this belongs in the "Photograph Gallery" Please move. Thnx. |
Nice Work! They look good.
I have the same strut tower bar as you. I never bought the chassis brace because I am really low and afraid of scraping it or bending it etc. |
If you did the springs and both bars at the same time it must feel like a whole new car.
I think that lower tie bar would do alot. But when driving I put obsticals under the car,That bar would'nt last too long I'm thinking. I already bang I lot of ground on the eibach's. |
Is it possible to flip the bar for more clearnce,or would the down pipe be in the way ?
Originally Posted by richardparker
(Post 11874547)
I think that lower tie bar would do alot. But when driving I put obsticals under the car,That bar would'nt last too long I'm thinking. I already bang I lot of ground on the eibach's. As far as clearance, it's really not as bad as people would say. I was concerned about it A LOT! If you go lower than the Eibach spring drop than you might have issues. The only issue I had was a trash bag on the road I couldn't dodge and didn't see it come out the back so the bar was actually dragging it... The good thing about the bar is it's position. The position of the bar is where the wheel is... so, if you go up a speed bump the bar would obviously go up with the car. |
:yum: i want the FD3S
where did you get that cusco bars from?
lookin good...love the blue coated base
Its looks good, but Im not a fan of strut bars that pivot.
Originally Posted by cu0ngsayz
(Post 11875242)
(Post 11875242)
Marcus had to get them in from Japan. I paid a little more to have them expedite the shipping. Every penny worth spending. |
Sweet setup dude!
I have the lower brace on my 1G CL and it makes a world of difference, drop and such looks good. Bump for marcus (heeltoe) The best place to get cusco stuff
I just hit a fat ROCK. There is a nice scratch on the lower bar but wow! the sound was not pleasant AT ALL.
^ Im afraid to run the lower bar for that very reason.
well the fact that, that only took three days makes me not want this so much any more
It's a nice piece for track use.
Everyday driving it's bound to have issues. Some one thats good with welding should try fabbing up one that fits really tight for more clearance. I'm sure alot of us would get one if it was more practical for the street. |
As much as I love it I think I am going to take it off and just save it for track use. I haven't ran into any more issues but I am so paranoid when I am driving. I have my eyes open 0_0. I want to pleasantly drive.
Originally Posted by Nersh7
(Post 11882813)
(Post 11875576)
No pivot spot in this set up would cause serious binding till snapage of something : lower arm,or bars mounting bracket or bolts. A hard enough hit with that bar could have you looking for alinement issues for days, if you could not see what was bent after. I do like the bar. Auto cross or time attack is where you will see how well it performs. |
wait till you scrape it :hide:
(Post 11888366)
The lower bar has to pivot I think because it's bolted directly to the lower arm.
(Post 11889083)
it doesn't bolt to anything that moves.
I thought it bolted directly to the lower arms.
Where is the mounting location ? Any pictures of where/how it's mounted ? |
it bolts to the lower subframe bolts that bolts it to the body, not quite the lower arms but very close to the arms mounting points though, so it still does stiffen it up
how is the ride with the eibach lowering springs, like is it harsh and feel every bump? do you have stock struts?
Originally Posted by 03type_s6speed
(Post 11893351)
The drop isn't as low as I would want you can tell by the pics. I am going to get the Koni Yellows so I can drop it a little more. |
(Post 11890296)
