crazy brake idea question
Old Oct 14, 2006 | 05:35 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
I got my front slotted and cross drilled rotors w/ new pads on about 600 miles ago and man the braking difference is amazing. But I was thinking, I have my old set of stock front rotors and while they are current warped, would it make any sense to put those on the rear? They seem to be a decent amount bigger. I can get the old fronts resurfaced for free, and while the rear ones are fine, would this be a waste of time, even if it was possible?
Old Oct 15, 2006 | 11:03 AM
Type S Zero's Avatar
offset is far from being close, and parking brake mechanism won't work (and will be prone to receive dirt and rocks)
the caliper ain't large enough (or you would have to use it with worn pads) disk difference :
9mm vs 27 mm (new pads are 9.0mm of braking metarial + metal.....)
you could probably fit front calipers with custom made brackets
but i'd be worried about brake force balance front/rear + brake pedal going to the floor to have some power because of the large difference in piston diameters, the master cylinder wouldn't be the appropriate size
there's no way you can do this with simple modifications
Old Oct 15, 2006 | 02:21 PM
Thanks for the detailed answer. . I think I will leave the brakes as they are for now.
marcelft
Jul 10, 2018 06:17 PM
nuldabz
Sep 3, 2015 05:49 PM
nishant11
Sep 2, 2015 10:34 AM
darknite123
Integra
Aug 30, 2015 03:00 PM
