Cold weather and my shock??
2001 CL-S
Ok so heres the deal, my right front shock has been squeaking for the past month or so and its driving me insane, idk what the hell it is. Ive takin a look under the car and around the wheel, but dont see anything out of the ordinary. I think it might have something to do with the cold weather b/c it warmed up for 2 or 3 days and it stoped and now its back again as is the cold. Any ideas on what might be up, or should i start saving now for some new ones?!?!
Try this!
Why don't you try this Acura CL shock absorber, it provides a smooth, secure ride with excellent control for drivers who are looking for ride comfort and improved handling. And its excellent performance under the roughest conditions.
Try check your tie rod end and/or ball joints. Actually that happens to my Acura TSX, I used it for racing (have a bad tendency to go dry and squeak like crazy) so I purchased and change a new Acura ball joint . If they don't have grease fittings (and a lot of them don't) shoot some wd-40 or equivalent in there and see if it stops the squeaking. then figure out whether or not you need to replace it based on how much play there is... you probably need ball joints anyway. Hope it helps....
rcs86
08-02-2016 06:52 PM
