can i use 245/*/17 tires on my type s?
Parting out 02 Type S :(
lets put it this way. tire places would highly recommend against 235's. now, putting 245's means that you would have the tire tucking in alot, hence more sidewall flex than intended. also, you will be altering the contact patch to the ground, and essentially the tire wont fuction in the manner it would was meant to.
i doubt you would see a benefit from this size on your stock rims, and you risk the possibility of the tire coming off the rim under heavy cornering. driving normally you can probably get away with it.
Liquid Ice
Aren't the stock Type S rims 17x7 not 17x7.5? ...
I know the TL-S stock rims are 17x6.5 (super thin), and I thought the CL-S rims were only one size wider?
13.68 @ 102.56
The rims on my car are 17' by 8' and I run 245s all the way around. I had to modify the rear lip in the wheel well. It it is pastic so that is easy to do.
1fatcrxnem1
22
06-01-2018 01:23 AM
sockr1
10-01-2015 01:31 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
