camber help
Originally Posted by Louie11
He must have camber kits already because the before is different than the actual. Was this done at acura on their 4 wheel alignment machine?
camber adjustments were well done and are ok numbers so you won't eat up your tires interiors but still have a good cornering.
but your toe numbers are not good : 0.14 total front toe is very near spec limit (i never stop adjusting if beyond 0.02 when i do alignments... and leaving it at 0.02 is when i'm getting out of patience) at least get 0.01 and 0.01
rear toe ? 0.09 left and -0.01 right ? come on
it's easy to get the numbers between specs limits, but your final print should be very near specs (front toe : 0.00, rear toe 0.08.....not total toe measures here, individual measures)
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
