Bushings and rattles... need suggestions
My car is making a squeak, rattle and boing noise only over uneven bumper road. No noise when driving slow. 30k miles, mostly city. I think my shocks are still good, I'm on OEM shocks and had the car lowered on neuspeed springs for 15k miles. Wondering, how hard is it to change the bushings? I mean, I know the sway bar end links my moog would be a good change, but what about the other bushings and where are they? I'd love to do it myself. Any sites of where to get them, any body do this?
you'll probably need new joints i have that same squeaking problem. when you turn ur wheel does it make a noise? If so i think it might be your ball joints. your upper ball joints are on the control arm and the lower one is right under your disc brake. When i did it i replaced the whole control arm and hammered my lower ball joint out.
Whats up with RDX owners?
Are the noises coming from the front or rear?
Sounds like the passenger side front is doing all the squeaking, and the passenger rear makes a slight occasional knock. Funny, before this winter, the car was dead silent.
My plan is to first change the end links on the sways, then the bushings. But first I want to get everything myself and see if it can be done in my garage. I'll make a trip to the shop to have something pressed if need be.
Any sites that can explain what I need and sell them? THinking Ima go with OEM replacements. I heard the urethane bushings make everything too stiff.
Right at the beginning of the winter, my shifter bushings felt like they were on their way out, so I changed those too. maybe the rubber bushings are all starting to show their 7 year old age, and the shifter bushing was just the first to go with the suspension ones now following?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Definitely sounds like a bushing Ron, I had this same problem on my 1st gen, it turned out that the rubber bushing had disintegrated and the suspension was moving in directions it wasn't supposed to. PU Bushings are a great change but from what I understand they don't make a full kit for your cars. Installing them isn't bad if you have a shop, but you'll need to press out the old ones and press in the new ones
Update: I switched back to the 18" Harrows with 255/35/18 Pirelli rubber (really soft and squishy) and man, the car rides so different, like she used to.
I guess the Nitto NeoGen tires were a bit too hard and it really threw off the ride quality. I mean, I rode on 225/35/20 before, but they were Toyo Proxes 4, and they didn't feel liek the Nittos.
Might still get some Koni Yellows and drop the car a bit more on the lower perch, and keep the springs. Think I'll put on some sway bars too and refresh the bushings and endlinks while i'm at it.
kb1rl
09-30-2015 10:17 AM
