Best Spring / Strut Combo for Ride Quality
takin care of Business in
Received 4,732 Likes
dude there are about 2 dozen threads on Azine with the same question....please search before you open a thread....no pain no gain !!!
Senior Airman
I have Eibach Springs on Tokico HP's and I absolutely love the way it looks, feels and handles. It rides a little rougher than stock, but you can comfortably go over speed bumps with no issues.
I have had my setup for over 3 years now with no issues, both the Eibach's and Tokico's have unlimited warranties (provided you installed them correctly).
It all depends on your preference of height, quality of ride and the amount of $ you want to spend. If you want to be slammed, go with coil-overs but be careful b/c if you go with a cheap setup you will quickly regret your decision. (They look beautiful tho if you have the funds to invest) GL.
Senior Airman
Then go with Eibach pro-kit with Tockio HP shocks, I have this setup on my DD also and cost me about $350.00 since I installed them myself (also got a crucial deal on the Tokico's from ebay)
Also you need to remember that we share the same chassis and suspension as the 98-02 accord v6... This may save you a little bit when looking for suspension mods.
Sweet. Thanks.
Former Sponsor
There are a number of great combinations out there, including Eibach springs and Eibach or TOKICO Dampers. If you want an even better setup you could do KONI Sport shocks. Another good, very reasonably priced combination is the B&G setup.
http://store.excelerateperformance.c.../i-232409.aspx
Senior Airman
there are a number of great combinations out there, including eibach springs and eibach or tokico dampers. If you want an even better setup you could do koni sport shocks. Another good, very reasonably priced combination is the b&g setup.
I suggest Tein H-tech springs. They lower the car 1.2 all around and gives a very comfortable ride. I can take 3 hour trips with my parents in the car, no problem. It's not too low so that you wont scrape on driveways.
While this is true, our cars are also much heavier. This will result in lower drops and possibly changed ride quality by installing accord springs on our cars. So if possible, get springs that are made for our cars.
Senior Airman
Registered Member
i got the eibachs installed, the improvement was noticeable but I'm waiting a bit for the springs to settle before taking good pics. this is a cell phone one for now. it definitely looks good in the back, but there is still some gap in the front. hoping it settles a bit after a few hundred miles. i think removing my stock rims and upgrading to 18/19's will help too.
the shop wrapped up my my stock shocks/springs in the Eibach packaging and it's ready to ship. what would be a fair asking price for a set with 69k miles on them? I see a wide range on the market.
grainy cell pic for now:
3rd Gear
i'm thinking about running Tokiko HPs and the Eibach Pro kit setup on my '01 CL-S but I've heard that I may need to run camber arm kits on the rear. can you guys testify to this? i should be fine with just getting an alignment done after installation of the springs rite?
Former Sponsor
i went with the koni yellow SP3s (neuspeed) they have 5 perch postions and i also went with the H&R o.e. sports the adertised drop is .75/.50 but reality is very close to 1.0-1.25 all four corners ... early on we found that most springs had a lower than advertised drop on the CLS most noticably to the rear which to me gave it a rear end sag that i didnt like ... nice thing about the konis is ... u could easily drop the fronts another .25 to .50 or raise the rear the same to achieve a level looking drop .... for me my 1.25 x4 was perfect
emailnatec
29
09-28-2018 04:27 PM
lanechanger
10-13-2015 10:56 AM
