the basics....Tein Basics
Old Apr 2, 2008 | 10:28 PM
teinCL's Avatar
RIP Dodge Shadow
i wanna drop another 1/2"-3/4"....how many turns do i need to lower the seats? or does 1/2" down the threads with the seats equal a 1/2" drop? anyone....?
Old Apr 3, 2008 | 12:56 AM
02type-s's Avatar
-Arsenic-
I just adjust my SS until it looks right
Old Apr 3, 2008 | 01:52 AM
Ravi621's Avatar
i remember speaking with someone from tein any they said the coilover comes 1 inch shorter from the factory. so i think 1/4 from the top might give the drop. i just did it like the reply above. do it till it looks right.
Old Apr 3, 2008 | 07:26 AM
smokendsm's Avatar
ridin slow'n'low
I thought this is how everyone did it. Just double check the height from the jackpoints to the ground to be sure its even all around.
Old Apr 3, 2008 | 08:28 AM
teinCL's Avatar
RIP Dodge Shadow
i was just tryin to avoid jackin the car up...jackin it down...jackin it back up...blah blah blah. i mean i do have to jack it up to lower it right? cuz thats what release the tension off the srpings to be able to adjust them.
Old Apr 3, 2008 | 10:45 AM
brianlin87's Avatar
ASM I.S. Design FTW.
with your spoke pattern you should be able to lower the tein coils without jacking up the car at all to your desired ride height.
Old Apr 3, 2008 | 11:46 AM
smokendsm's Avatar
ridin slow'n'low
On a slightly related note, invest in a decent floor jack. Preferably a low-profile one. It will make your life easier.
I picked up a 3ton floor jack from harbor freight that does its job very well, but it barely fits under the side jackpoints with about less than an inch (maybe 3/4") of threads left on my teins.
Old Apr 3, 2008 | 01:34 PM
02type-s's Avatar
-Arsenic-
LMAO good luck with that. The weight of the car is resting on that adjustable perch you are trying to move. You need to jack it up, it will save you a lot of TIME.
Old Apr 3, 2008 | 05:47 PM
DLntheCL's Avatar
agreed. you will save more time by jacking up all 4 corners and having adequate room to get your arm in between the tire and fender than trying to squeeze inbetween a spoke. i would think that 1/2'' down the threads would equal 1/2'' lowering. i just get one side done how i like it and count the visible threads on the bottom and match the other side. F and R is different i think.
Old Apr 3, 2008 | 05:54 PM
teinCL's Avatar
RIP Dodge Shadow
word...yeah thats what im thinkin too, seems like the best way anyways. thanks. how those 20's workin out for ya? i sorta regret not gettin 20's a little when i purchased my 19's.
Old Apr 5, 2008 | 01:08 PM
teinCL's Avatar
RIP Dodge Shadow
wow...much easier to do than i thought. definitely gonna play around with ride height more often, but im pretty pleased right now even though i only dropped down about 1/2" to 5/8". down to about 3/4 of a finger gap.
Before:
After:
we'll have to see how long i leave it at this height seein as how my camber is WAY negative now...no camber kit here
Old Apr 5, 2008 | 01:15 PM
02type-s's Avatar
-Arsenic-
Looks mUCH better! Keep in mind tho, every time you adjust those, the alignment is off.
Old Apr 5, 2008 | 01:27 PM
teinCL's Avatar
RIP Dodge Shadow
thanks man...yeah im just gonna keep an eye on the treads and see how they hold up before i go spend 90 on an alignment
IBankMouse
Jun 13, 2020 12:53 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
