Anyone running 35 series 18" tires ?
The last time my car was running I was getting a bump'n from the back that felt like a bad tire.
Today I went under the car and sure enough my rear tire was down to the belts on the inside.
I have 2 proxie fz4's in the back,and 2 nexxen 3000's in the front and they are 225/40/18 that have about 7k.
I found 2 nexxen 3000's for like 145 shipped and it will make a matching set but they are 215/35/18.
I was thinking of putting the new pair in the front it should make the front sit a little lower.
Then I going to get the 4 rear arms to unliminate future issues
How's the ride on the 35 series compared to the 40 series ?
rotating tires,No
When I find wear they get dumped.
It x mas time and I'm still spending everyday.
This was the best deal I could find for simular tires that will make a set.
I need to order a pair tonight. So If anyone knows where I can get my oridgenal size nexxen 225/40/18 speed rated Y for less than 150 shipped let me know.
the other rear seems fine,I just buy them in pairs.
B A N N E D
rotating tires,No
B A N N E D
those are wide even considered against the tire label (i see quite a few of the labels (on different brands though, but the labels seem to be pretty standard size though) on a regular basis), and sweet no rolling needed, but did the tabs need to be trimmed (sounds like they did not need to be)
Former Sponsor
B A N N E D
btw: i just got some a-spec 18-8 " rims recently (and i think right around 48 offset too), that is why i am asking
thanks
Ron, so do you think I could do a 235/40/18 on an 18x7 wheel, because that is what keeps speedometer the most correct. I know that people do put 235/45/17s on stockies, is this the same idea for plus sizing for an 18x7 wheel and im okay?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
35 is an awefully thin tire, I'm scared to hit a pothole with a 40 series
Ultra Negro
Use the tire calculator here
http://www.1010tires.com/tiresizecalculator.asp
40 series seems to be the way to go with 18's anything less and I would be scared to hit a bump, but thats just me.
Former Sponsor
so then how much is that car dropped about, cause l know i am on h&r's that have sagged a little bit over the years, and yeah i know every tire is different in that they geneally round it to the clostest available common size
thanks
thanks
from 215 to 255, all depends on both specs together.
On a side note, I'm gonna be running 20" rear wheels with 255/30/20 pirelli's this summer and the 18" in the front for a psycho look with the performance. Matte Bronze powdercoat finish monoblock forged lightweight wheels in the front (18" x 8.0" with 255/35/18 Pirelli P-Zeros) and 3 piece DT3-F wheels (20" x 8.0" with 255/30/20) in the rear. The only difference between the 18" fronts and 20" rears will be the rivets, diameter and lip size.
Gonna look sick, sorta similar to this:
Ultra Negro
You might have to roll the fenders to fit the 255/35/18 tires. Also, the A-spec wheels are a 45mm offset, and at this point, every mm counts regarding the rubbing or not.
Not really, it says that they are meant for a 8.5" width, but they fit and drive fine. i beleive the width suggestion just ensures that the 255 tread width is accurate, but in my casse with the 8.0" width, it might really be more liek a 250 tread actually making contact with the ground. No biggy. Just more comfort for me, lol.
Not really, the series # is actually an aspect ratio of the first number, thats why when you see a 305/25/18 or something, it sounds thin, but its sidewall is the same as a 255/35/18. So the series number is not fixed across different width tread specs. Hard to explain, but my tire sidewall of the 255/35/18 is the same as a 235/40/18, same comfort, more grip.
Might be a tad smaller than suggested, tires will have to be slightly over inflated to compensate for the weight of the vehicle. I ran those tires for a while with no big problems.
Not to sound like a know-it-all, but I like to makes ure everybody understands. It's all relative to the first number, people run everything from 45 series to 35 series on the 18",
running anything less that what the site recommends will throw your speedo off.
Whats up with RDX owners?
Hey RJ, when I run your 255/35 tire through the calculator against the stock 215/50, it comes up as being .5" shorter in tire height, thus 1.7 percent off at 60mph.
Did not know that.
B A N N E D
and most calculaters base their calculations on the width that is given (so they would use 255, when the tire actually might be 260, but is rounded to 255)
and the aspect ratio given (and not the exact aspect ratio it truely is [again rounded off])
Ill keep that in mind when shopping for my next set of tires.
I've went threw a bunch of differnt tires and these grip really well in the warm weather and the rain also.
But,winter: Ice and snow forget it they will just spin.
I'm not living in boston anymore so winters really not a problem living in NC.It only snowed once this year so far here
You get beat down in jerzy from the snow,and I would not reccomend them either.
For a cheaper brand tire they keep up for me.
The only time they have ever slipped or even made noise was either the winter or when trying to burn tires.
I'm a repete buyer of these tires.
Ultra Negro
I just prefer the 40 series so that less chance of getting a blow out, I live in the south suburbs of Illinois and we sometimes have long periods of no road repair during the winter.
Last thing I want is to replace a tire because I hit a pothole, especially when it is cold.
B A N N E D
1fatcrxnem1
22
06-01-2018 01:23 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
nuldabz
09-03-2015 05:49 PM
