Another Wheel Offset Question
Old Jun 23, 2007 | 10:20 AM
Tweek's Avatar
Caffenine Addict
Doing some research on some wheels. Seems pretty difficult to find a wheel that will fit when we lower our cars. I will be lowered on Ksports. Dont want to go any bigger then 18's just for tire cost mostly. Anyways, I really like the Gram Light T57-RCs.
Anyways they have with a 7.5, 8.5, or 9.5 width. I think the 9.5 is to wide for our cars. The 7.5's have and offset of +48 and the 8.5 offset is +45. Just wondering if I would have have problems with these being lowered on Ksports. If so what is the optimum offset I would need for an 18 inch wheel being lowered on Ksports?
Appreciate it,
Tweek
http://www.forperformance.com/rays/w...7rc/t57rc.html
Old Jun 24, 2007 | 02:45 PM
distortedolskool's Avatar
if you plan on slamming your car the 8.5 +45s might have some rubbing issues, others please add advice. the 7.5 +48s will work with some rolling.
some where in one of the 948 wheel threads someone posted an optimum offset for size wheel grid.
Old Jun 24, 2007 | 07:32 PM
Tweek's Avatar
Caffenine Addict
yea. just got home from work. Im going to search now.
Old Jun 24, 2007 | 10:34 PM
cltypeSLOW's Avatar
Don't Mess With Texas
the 7.5 +48 will fit perfect. no rolling needed. you could even run a 5mm spacer if you wanted it to look a little more agressive.
Old Jun 25, 2007 | 05:07 PM
cltypeSLOW's Avatar
only reason i said you could run the spacer is because of the 7.5 width.
if it was 8 wide then you would need +48 to +51 closer to +50 would be optimal, but we are talking mm, so its not THAT important. as long as its in that range if you are running 8" you should be good.
Feb 25, 2020 09:57 AM
BreezyTL
Jul 26, 2016 12:52 PM
DunesCreations
Sep 9, 2015 12:03 PM
nuldabz
Sep 3, 2015 05:49 PM
bailey24
Aug 31, 2015 05:38 PM
