Adding to upper balljoint stroke
it was mentioned in a thread started the other day here is the link https://acurazine.com/forums/2g-cl-tires-wheels-suspension-54/why-we-recommend-rear-camber-kits-without-ball-joints-775337/
btw you should probably put this type of post under the suspension section. Refer to RooEng's post.
B A N N E D
sorry old accord lol, i sold it when my TL came up for sale
but yes it did fix the noise those, don't get me wrong (only to a point though, it still bottom out occasionally though ), but i would probably not ever do it again though, and just go the stiffer springs and shocks route (such as coilovers) (i was still on the stock shocks with 100k on them )
B A N N E D
btw that fuse won't do shit being that amperage, wire can't handle that, so it will butrn up first if something shorts, and even then if you are really pulling that power (if the alternator could even support it), you should have a couple of batteries or something in the back
and figureing that is 1/0 gauge wire or so
A little off topic but,I can roll with it.
My sub amps pull 320 amps. My wire can flow 300amps
I have all 0 gauge wire. Done big 3
300amp fuse under hood, block in the back splits to 2 150amp fuses,
0 right to the amps with reducers.
Amps are both grounded seprately with 0.
I had two batts in the back before.
Now I only have one under the hood and I'm running my amps only at 2ohms now insted of .5 ohms.
So they are only putting out 1100 wrms each right now insted of the 2000 each they are capablerunning @ .5 ohm.
audio I got a good handle on what's going on.
I know all the things I need to run everything correctly.
I'm just easy with it since I do need a bigger alt and at least one extra batt.
B A N N E D
fair enough, but i would still put those batteries back in the back though, and then maybe at least downgrade that fuse up front, since you want that to be the weakest link in the system, and not the wire itself (remember you probably got 15 feet of wire from the front to the back of the car; and the heat underhood for that small section, which all downgrades the rating on the wire, so i would rather play it safe, nd possibly replace the fuse occasionally then be replacing a car burnt down to the ground
I was about to reply to your other post. Mine looks like Richardparker's, I think it was his picture I found while searching the problem a while ago. I just did what he did and like friesm2000 said, just center the drill on the pimple.
I know your not driving that low.
Coilovers slamed,or not strut present ?
The only rubbing issues I have now are my tires are just too high to ride with mine slamed.
Parked on a flat surface I can lock out my wheels and it's barely touching.
Cornering it rubs.
So I guess I have to up the front a little.
I want it low as possible so I will be adjusting only 1/16" at a time till I can deal with it.
I tryied pulling the fenders up but,it turns the botom of the fender near the door out and it make the lines look like crap,to me anyway.
Cornering it rubs.
B A N N E D
Cornering it rubs.
Cornering it rubs.
After making the circle holes for the upper nut to come threw.
I've made 2 circles off of each circle that would make them look like a mickey mouse symbol,so the arms could come threw.
I was still getting hitting and I could not see anything.
Come to find out it's the mount for the abs wire on the upper arm that sticks off a little.
I'm going to do some griding and see if it clears for no noise with out removing first..
If it dont, then the mount comes off till I can make it clear then drill new hole for the mount.
adreano17
09-29-2015 08:48 AM
