7th gen accord dyno--- 208hp and 180lb at the wheels
Full-Time IDIoT---DoH!!!
7th gen accord dyno--- 208hp and 180lb at the wheels (dyno and video inside)
Guys, i'm going to enclose a dyno from injen on the new accord v6...they just developed an intake from the car and that is what they got the number from (also, note those those are max hp#s):
heres the post from the injen rep on the accord site:
Wow, i think w/an intake the accord v6 may give a cl a run 4 the money, plus, u must rmbr it weighs at least 150-200lbs less than a cl/tl and has a better tranny gearing as well....also, the car dynoed had 18"chrome wheels
This post is to inform new Honda Accord V6 owners that Injen Technology has released a Cold Air Intake system for that vehicle. This intake system will be under Injen's Race Division line and will be part # RD1675. I have attached a preliminary dyno chart from our facility for you guys to look over. This is an actual dyno graph from our in-house Dynojet. It is not one that is drawn up by some of our competitors. Please look it over and review it. You guys may be skeptical because it is a manufacturer dyno, but overall the gains are impressive.
If you have any questions, please feel free to contact info@injen.com
This intake system is pending CARB approval.
Best regards,
Phillip Phong
Injen Technology
www.injen.com
Best regards,
Phillip Phong
Injen Technology
www.injen.com
Moderator Alumnus
wow, with 18" chrome wheels too. That car is pretty impressive. Didn't someone post a 1/4 mile time of a mid/low 14 for it also?
lol, now we all really do have glorified Accords
Happy CL-S Pilot
Even more..... are those the stick or Auto? if Auto... 180 lbft is even higher than the stock CLS torque of 175 lbft
But damm it 20 lbft of torque all across the range is never heard of from a CAI
Have a custom high flow headers and you are doing 225-235 WHP easy!
you know, lets think about this for a second.....when coming up with the design for this 2003 accord, honda had to deside how much power to give this car...so they said, ok 240 hp....now, after seeing that stock dyno....i dunno, thats some high numbers there...thats almost CL-S territory on that dyno, and thats only 1 dyno....but stilll....maybe the new accords simply just have the same motor as the CL-S motor and honda is claiming it to be less power..it would be cheaper to do that since the CL-S motor is already built and mass-produced....and its a damn good engine, why not just use that for the accord and publish slightly lower numbers so as not to upset the acura people. im no expert, but that dyno video its basically indistinguishable between a CL-S engine and this new accord...that motor looks like it has the EXACT same motor as the CL-S, the only differnece on the intake was another bend, which is due to the exterior shape of the fender, hood and other underhood components not related to the engine itself. i think its entirely possible that the new accord has the same motor as the CL-S, with the exception of the new exhaust manifolds that apparently dont allow for headers, its probably the same block, heads, intake manifold system, cams, crank, everything.....nissan already is pulling a fast one like this on maxima owners...the new altima that has "supposedly" 15 less hp is dynoing the EXACT same as a maxima with the "supposedly" extra 15 hp. it sounds like its all marketing to me. its cheaper for honda to use the CL-S motor than just re-design another one that does exactly 240 hp....maybe the new exhaust on the accord is designed to de-tune the CL-S motor a bit and bring it down to something close to 240 but from the look and sound of this, that accord most likely has at LEAST 250 at the crank as it is highly likely that it is simply nothing more than the CL-S / TL-S motor with a different exhaust
well jim, supposedly the accord gets an extra 10hp and 7+lb from premium gas...hmm u maybe rite abt the exhaust as well, the accord may get good gains from a new exhaust
The Acura Granddaddy
Ummm....Im surpised that no one noticed that HP and Torque do not meet at the proper place on the graph. I think this dyno is BS. Both graphs should have the convergance at the around 5252 RPM, the graph with mods is just "shifted" to the right.
well i inquired abt the type of fuel grade used and heres their response (from injen):
We use the recommend octane rating from the manufacturer for all of our Dyno testing. Since this new Honda Accord V6 designates "Premium unleaded gasoline", and in California that means only a 91 Octane fuel rating, we do not and will not use any type of enhancements to provide false readings. Other states still offer 92 and 93 Octane which will probably yield even more horsepower gains.
These intakes will be available early January from our dealers. The MSRP is listed at $320.00. However, you should contact our dealers for actual pricing.
Best regards,
Phillip Phong
Operations Manager
Injen Technology
Best regards,
Phillip Phong
Operations Manager
Injen Technology
acctually the accord recomends regular unleaded that was one of its big draws...but...later a tech said ..."but if you goto premium then you'll get 10/10" ...and last question...i dont know and am not interested enough to look but do the new accords redline at 7K????id be surprised
More here...
http://www.v6accord.com/forums/showt...threadid=17420
Grammar Police
The two curves on a dyno intersect at RPM = 5252 if and only if the TORQUE and HP vertical axes are THE SAME...
The reason is that HP = (Torque * RPM / 5252). Torque is always EQUAL to HP at 5252 rpm, but this doesn't mean they'll be in the same place on the graph if the scales are different.
If you will look at the graph, you'll see that the HP scale on the left side doesn't match up with the torque scale on the right side.
If you look carefully at around 5252 RPM on that graph, you will see that both HP and Torque are around 168-169 for the baseline graph, and around 180ish for the Intake graph.....
EDIT:
Well someone beat me to it, but hopefully my wordy explanation wasn't wasted and someone will learn something
DiamondJoeQuimby
09-10-2015 11:40 AM
nuldabz
09-03-2015 05:49 PM
