50K Miles out of my Tokico Blues?
Veni, vidi, vicious.
Hey, long time no see! I put a set of Tokico Blues on my '03 CL-S 6SPD with Eibach springs, four years and 50,000 miles ago. With the ride slowly worsening lately, I think it's time for a replacement.
Question: I recall that I needed new bushings to go along with the new shocks, but not which ones; what new bushings should I also get before again replacing the shocks?
Question 2: does this seem like a reasonable amount of longevity to get out of the shocks?
I have a similar set-up where I used Tokico Blues with CT springs. At 115K, the struts all needed replacement. At that time, I had about 70K on the Tokico Blues and 115K on all of the strut rubber components.
When the front struts were replaced, I ordered #7, 11, 17 on the link below:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
When the rear struts were replaced, I ordered #8, 10, 14, 15 on the link below:
If you desire, you could replace #7 on the fronts and #8 on the rears with 51631-SEP-A01; 08 TLS Front Shock Absorbing Mounting Rubber. This is what I ended up doing and these are discussed on the link below:
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/suspension-modification-765843/
Or you could buy coil overs. Use the Search to find out all kinds of info.
Good Luck
Good Luck
nanos
11-12-2015 08:41 PM
BobbyGraham388
10-22-2015 05:05 PM
