3rd Gen TL rims for my CL?
None
I was actually wondering what size tires is recommended for the 2006 Acura TL rims. I would like to put them on my cl. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
dno how to post pics, but i post a linked with pics of the rims.(who ever has that car, very nice)![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
https://acurazine.com/forums/ramblings-12/bcs-190981/
None
tire size for a 17x8 rim??
hello. im looking into putting on the 3rd Gen. TL rims on my CL. Just dont know what size of tires are needed. any recommendations are nice. ty
None
hm, what about the 03' type s rims. the ones you have fuzzy02CLS. which tire size do u use? im not planning on lowering it. btw. atleast not for a while.
gotta love them anthracites!
Mmmmm...sausage...
Originally Posted by fuzzy02CLS
235-45-17 is a correct speedo match.
However TL rims are +45 offset, if your lowered you may rub.
You can use 225-45-17 as well, to help cure rubbing problems, but your speedo will be a little off.
Threads merged, no need for 2 on the same subject.
I had stock springs. YMMV.
Jabo
None
ya. people are telling me the 215/50/17 works with the tl rims which are 17x8, especially when im only using stock springs. hey jabo. u have the exact same rims as fuzzy, right?
Mmmmm...sausage...
There are multiple threads on this forum with what appears to be conflicting info.
On another thread, another owner indicated and posted pics to show that 3G TL rims with 235/45-17 tires will fit with no problems. He has stock suspension setup.
https://acurazine.com/forums/showthread.php?t=190981
So to help the fellow owners in this direction, how about the folks in the know help out here.
If using 3G TL rims (17 inch, 8JJ width, 45mm offset), what tires will fit, and what potential issues there might be? Stock vs lowered?
- 215/50-17 (same as stock CL-S) No speedo issues. But 8JJ width is wider then recommended for this tire size by most mfg.
- 225/45-17 (speedo issues?)
- 235/45-17 (no speedo issues but rubbing?)
Please chime in and help clarify the issues here.
Thanks.
Thanks.
Moderator Alumnus
Honestly, if I had to do it again, I'd go with 225/35/17s just so I wouldn't rub. The only time I do if there is a bump in the road from constructions thats about 4 to 5 inches in height.
i'm running 235 45 17 on the tl rims and am lowered on tien ss with about 2 finger gap. no rubbing problems at all. occasionally i get minor rub on big bumps but i think that would be fixed if i stiffened the shocks (i have them set really low)
also no real problems with the speedo
Keeping the Stealth alive
Originally Posted by cbusAcuracls
^ wow your rearend is low. You must not be able to put anything in the trunk on that baby.
Rims/tires look good though.
emailnatec
29
09-28-2018 04:27 PM
