38mm offset
No. They will rub.
Offset is the distance from the hub mounting plate to the center line of the wheel. It will influence how much the wheel sticks out towards the edge of the fender. If the offset is too low, the wheel will rub. Try to stick between +45 and +55. You may be able to get away with a +42 in some cases, but usually on a 7 or 7.5 inch wheel.
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
