245-45-18" tires on my 04 maxima
whats up guys im taking my 04 maxima to the track.. what should my tire presure be set at normaly for driving on the street? and what should i set them at for the track?? i want the best launch at the track with these tires.. but i dont know what to set them at stock or for the track.. can u guys help? thanks in advance.
x
Originally posted by Nashua_Night_Hawk
if it is hot start at 32 PSI. if you have hops lower it to to 26 PSI
I dunno but pls post a review of the max!
When I bought my TLS the 02 Maxima SE was a close second. The suspension was as tight as the TLS but ultimately the TLS won out.
But the new Max is one of the hottest looking cars bar none!
Pls post your impressions!
sure ill post a review. i have a black on black 04 maxima fully loaded nav everything... the car is great quad exhaust coming out the back and fast to... the suspention is nice and tight and handles very very good for a big car... my brother has the 03 cl-s and there both about evan but i actually take the max over the cl... its different looing.. i ahve the skyview sunroof which is awesome it streaches the full length of the car i love it.. i would highly reccomend this car to people.. im hoping for 14s at the track... the new 5spd auto is nice.. the only down fall is the tiptronic shifts by itself if u dont shift the gear. so for racing it doesnt help form a dead stop.. but from a roll it does work u can down shift nicley...
hMMM, I thought this was maxima.org but it is not.
Also check, mycarlookslikeasatrunIon.com/bucktoothgrill//overpricedcar
x
Originally posted by Gilgamesh
I think that people should feel free to come here for general car knowledge, I will, long after my TL is gone.
Okay dude, Set em to about 20psi on the track. Keep your car off as much as possible (keep the engine cool). Go with about no more than a 1/4 tank of gas.
BTW, if u are using the stock tires, you need to upgrade to better ones as 99% of stock tires blow moneky nuts.
1/4 14.4 at 95
guys u have no more answers? comeon help a brother out for the tire presure? any ideas guys? i think 20 psi is to low im thinking 32 psi or 30? these are big tires i think 32 would be good.. and for the back 36psi???
I think it's all pretty much been covered...
Originally posted by fuzzy02CLS
Best tracking will be under 28psi front, & over 38psi rear. You have to adjust them depending on track conditions. For track in a FWD car you want lower front, & higher rear. Street driving I'd say 35-38 all around.
I pump my 235/40/19 nitto tires to 35-36 PSI on the street.
Back to the topic.. I would run the fronts at about 22-25 psi. And what psi are you at for everyday driving?
Originally posted by 1SICKLEX
:noob:
:noob:
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Originally posted by danny25
this ain't a Lexus forum either. :P
You all are too funny
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
Originally posted by spec v
thanks for your help
As far as your tire pressure issue goes IMO don't take anyones advice here. Use some of it as guidelines or a starting point but I'd say find a nicely paved parking lot and launch it, if you get the result you want write it down and keep it in mind for the track, if its not the result, raise/lower accordingly and just keep trying it out until you find something your happy with. Just keep in mind there are some variables with track temp and outside temp. Chances are when you have a setup that you think will work it'll end up changing at the track, and you'll have to adjust between runs anyway (P.S. I'd don't know if that kind of adjustment is allowed or not)
CostcoFanAUS
09-18-2015 06:05 AM
