235/40/18 +45 Offset
I've run the tirecalc on the
235/40/18 vs stock 215/50/17 on my 03 CL-6S
it's a .24% increase in diameter - or 60mph on stock rims = 60.1mph on these.
On the 225 tires though (because of the angle I guess) it changes to a .48% increase.
Anyone running 235/40/18 setup that can speak to the clearance of turning?
I'm stock height, but I'd like to drop it 1.5 / 2 inches with some springs.
The rims I'm looking at are +45 offset. Would I need to be more like +50 ? I don't want cone shaped rims.... damn FWD....
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
These are what I was considering.
I would probably spray them anthracite to match the CL - though the black contrast might look good - I dunno.
They're 7.5 wide. I think the 235s should improve traction a bit, maybe help the LSD work a little harder too - but I don't want to be cutting holes in my fenders or splash guards either. I DESPISE when the kiddies cram mis-sized wheels on otherwise clean cars....
I gotta admit, having owned both - the CL is a COMPLETELY different car with the 6 Manual. It should have been given a different name.
With a 2 inch drop and these wheel dimensions - would you think I'd need a good camber adjustment as well?
Agreed - I just don't want to be rubbing the inside edges off the tires in 2000 miles...lol. If I were to get +45 offset rims with 145 tires - might not be a big deal to drop it 2 inches.....235s on the other hand.....
You look at improperly adjusted cars from the back and see \----/ or /----\ instead of a nice |-----|
Pokin Holes In Tacoma
I have been on 235/40/18 tire on a 7.5" et 45 rim for 3 years now. I do have a tein ss drop that is 1.5 -2 finger gap all the way around. I do love to corner like a maniac so I have -1.2 degree camber in front and -.7 in the rear. Otherwise you should have no worries mate.
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
rockvilleTL
09-19-2015 04:44 PM
