19s Question... Help!
Old Sep 9, 2004 | 10:24 PM
Mongolian's Avatar
I know nothing about wheels....
I'm planning to order Racing Hart CR multipiece 19s as soon as find out which size fits my car...
19x8 with either 45+ or 48+ offset
or
19x7.5 with the same offset...
What tires should I be putting on ?
My mods are below...
Old Sep 9, 2004 | 10:37 PM
liquid_x's Avatar
i'd do 19x8 +48 w/235/35/19 thats what i have on and ur drop is conservative so u shouldnt rub. shouldnt bein the key word.
Old Sep 10, 2004 | 12:28 AM
kumar6's Avatar
yup what liquid said... i have the 235/35/19s and they are working... i have 19 inch rims with a +45 offset and it seems to be ok...
kumar
Old Sep 10, 2004 | 01:12 AM
sgmotoring's Avatar
Bleed Honda Blue
I think 19X7.5 will be wide enough.
Old Sep 10, 2004 | 01:16 AM
rondog's Avatar
Former Sponsor
48 offset on an 8" wide wheel isn't the same as a 48 offse on a 7.5" wheel, slightly different. I'd go with the higher offset and 7.5 inch if your worried about rubbing or dropping your car lower in the future, but all those specs you mentioned seem safe enough.
Old Sep 10, 2004 | 01:31 AM
Mongolian's Avatar
Thanks guys.... here goes nothing.... bye bye $2600
Old Sep 10, 2004 | 02:08 AM
Time For Sleeep's Avatar
That's Racist
-Keep us updated... with pictures.
Old Sep 13, 2004 | 06:46 PM
furious's Avatar
Go with 19x8 et 45
Remember the cls brakes are abit bigger. Ex try putting on a set of racing hart c-2 19" 1pc with a et 44 it will hit the caliper.
I would go with the et 45. I say a et of 48 is a bit to high.
Old Sep 14, 2004 | 01:46 AM
GOT PSI?'s Avatar
It's Go-Time.
I'm planning to order Racing Hart CR multipiece 19s as soon as find out which size fits my car...19x8 with either 45+ or 48+ offset
or 19x7.5 with the same offset...
For a TL, go with 19X8 with +48 offset and 235/35/19 rubber and you will be fine. But you may need to shave the rear fender tabs to avoid any rubbing.
Post pics when you get your wheels!
Old Sep 15, 2004 | 04:21 AM
nippon_wa's Avatar
nippon_wa 2.0
I got exact same rims few days ago for $2176 shipped.
RH CR 19s 19x8 42 offset.. (for the first gen) and.. 225/35/119 for the tires..
JDMEXI
Sep 10, 2015 10:01 PM
228
Apr 14, 2005 01:08 AM
