18X9.5 +35 fitment
18X9.5 +35 fitment
I am wondering if a set of 18x8.5 +35 F and 18x9.5 +35 R staggered set would need alot of work to get the 18x9.5 +35 to fit in the rear without rubbing on my 03 CL. Would they fit or would I need to run alot of negative camber and roll the fenders?? Would I be able to run a 235/40R18 tire?? Currently I am lowered on Tein Htechs, but I am going to be getting coilovers. Any help would be greatly appreciated, Thanks
my rims arent even running -3 camber and there wider than his. look at my rim specs. no offense but please dont give advice if you dont know what your talking about and i mean that in a not disrespectful way. i know how people can take things the wrong way on here. thats your problem how can you expect to fit those rims with -1.8 camber. i have -2.3 on my 10's. if you know anything about camber thats not a lot at all.
it can be done its just what looj are you going for fat low and stretched or tucked and clean.... im doing 8.5 et 45 front and 9.5 et 45 with 6 mm spacer and can almost tuck once my fenders are rolled i think i can go lower and am at only -2 camber rear.....
Yeah its still rubbing because your running some fat ass tires. try running 225/45 or 225/40 50 is way to big if you want to lower a car of course anyone would rub. I'm going with a 19x9.5 with a 35 offset im determined to make it fit while car is slammed we'll see how this goes probably -5 degrees in the rear and -3 up front. 225/35/19
wow dont go into the rim talk with diddy hahahah you messed up right there... and diddy knows what hees talking about because theres a few guys here that are running more aggressive set-up than he is... osiris just listen to diddy.. and i would put the coils on before i got and put the rims on...
Jul 16, 2017 07:33 AM
calrow
May 3, 2017 10:21 PM
adreano17
Sep 29, 2015 08:48 AM
nuldabz
Sep 3, 2015 05:49 PM
