18x8 wheels on lowered type s....
G.uns O.n D.emand
1 Post
i am going to drop my cl...heres my setup: tokico hp blue struts on tein h. techs 18x8 accord rims with 55 offset
HERES MY QUESTION!!!
WILL I HAVE ANY PROBLEMS RUNNING A 235/45/18 WITH THESE RIMS AND LOWERED? SHOULD I BE USING A DIFFERENT TIRE SIZE WITH THIS SETUP?
You sure the offset is +55 & they are 8" wide? If so they won't fit lowered or not.
The added width plus the stock offset or +55 will make the rim hit the inside fender near the strut.
You need to push the rims out a little. A +50, or +52, or +48 would be good.
You could get spacers though.
Also you want 235-40-18 tires. Those are the direct fit.
BTW I'll be in SI this weekend.
G.uns O.n D.emand
1 Post
G.uns O.n D.emand
1 Post
according to 1010tires.com the proper tire for plus sizing from 17x7 to 18x8 is 235/45/18...these keeps the speedo and odometer the closest to stock setup
i'm an idoit...225/45/18 is better then the 235...just checked 1010tires.com
this the best option for speedo...but i need more sidewall for n.y.c. streets are horrible...nothing is smooth here!!
handsom-hustla
11-13-2015 05:04 PM
