17x8 +45offset Is it possible?
Bumming It around LA
I was wondering if you guys know if 17x8 +45 fit in the rear of the CL-S? Is it possible or not. I searched and found a post saying that x8 should not have a offset lower then +48. If you guys can help me out that would be great.
why are you buying a set of 17 inch rims? i think the 01 17inch wheels look great with the 2 different finishes. if you get aftermarket 17s they are going to look too small.
6spder
1 Post
Originally Posted by fuzzy02CLS
Right, & some rub. Even with 225 tires you may rub with weight in the car. As I said it depends how low you are. Saying "low enough so that it wont rub" means nothing. You need to decide how much your going to drop it.
Your just going to have to test them. There's no right or wrong answer. They may or may not rub.
Keeping the Stealth alive
Close, but you should be good. All our cars are different. Mine has 235/45/17 tires and is dropped on Eibachs and doesn't rub, except a little up front on the plastic in the wheel well on turns.
![](http://i103.photobucket.com/albums/m157/JohnM142/0502071246a.jpg)
![](http://i103.photobucket.com/albums/m157/JohnM142/0502071244.jpg)
oh yea... my C2 has a little crack in it yesterday.
![Bawling](https://acurazine.com/forums/images/smilies/bawling.gif)
hey johnblayz, how low are you dropped and do you have a camber kit?
fangtl
04-11-2012 08:44 AM
