Where is the IAT Sensor Plug???
Hi,
I have a 2003 (3 trans) CL Type S with an AEI CAI.
I am trying to locate the IAT Sensor plug.
I'd appreciate some help.
Take care, Ted
Take care, Ted
The intake air temperature sensor is located on the backside of the intake manifold. You know the black plastic engine cover held down by four 10mm nuts...? The IAT sensor is located directly behind the upper right bolt if you are standing directly in front of the engine. It's a grey male/female connector with two wires, red & green with yellow stripes. It sits directly above the fuel regulator. It's easier to access if you remove the plastic engine cover. Hope that helps.
TinyTypeS
TinyTypeS
CD player problem
I have a 1997 acura 3.0 cl and my bose cd player does not play any cd's when you put them, all it does is display "PEO" and spits the cd back out, could someone please help me out, is this a simple problem? Thanks-
Thank you for replying.....
...but I traded my CL in last Thursday.
It needed transmission #4 (that's 3 in one year, 2 in two months).
Good luck to the rest of you.
Take care, Ted
Take care, Ted
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
