Water leaking on passenger side;need to clear out reservoir..how?
I have a 97 2.2 Cl. After the A/C is on, I sometimes hear water sloshing around when I turn a corner and then water will drain down onto the passenger side..and sometimes onto my foot on the drivers side.
I took off the plastic cover below the windshield on the upper part of the firewall...now, I have no idea what to look for or what to do next... I was told to use an air compressor to clear out drain lines, but I don't see where they are...
Anyone have a diagram or photo...or better advice?
Whats up with RDX owners?
This is the 2nd gen side GTFO!
The drain lines they are most likely talking about are the sunroof drain lines. Look at the front corners of the sunroof opening and you should see them.
Since your new, Ill explain that red text indicates sarcasm
