Vibration when breaking
Old Aug 18, 2006 | 06:33 PM
truongvo1978's Avatar
a few months ago i changed my brakes and rotars because of this problem.
but recently it came up again. Does anyone know what the problem is? Could there be a defect in my rotars or what?
Old Aug 18, 2006 | 11:09 PM
anthonya's Avatar
BANNED
Where are you feeling the vibration?
My steering wheel vibrates - left to right - when braking... however I am not feeling anything abnormal in the brake pedal.
The car drives straight and true, and the alignment seems okay. The only time I have an issue, is when I am braking - the steering wheel goes left to right... its messed up.
Is this the issue you are having? Is it worse when slowing down from 60MPH, and less an issue when slowing down from 20MPH???
Old Aug 23, 2006 | 12:36 PM
palanaki's Avatar
Ok, I'm having the same problem. I haven't changed my brake rotors or anything yet, but this just started about one or two months ago. My steering wheel vibrates when I brake, but I do not feel anything in the brake pedal. It is worse slowing down at higher speeds (ie 70 mph) vs lower speeds. Actually, I really don't notice a problem at lower speeds.
Old Aug 23, 2006 | 12:41 PM
RaviNJCLs's Avatar
The rotors on our cars suck. I'm guessing that you warped them again. I warped 3 sets of stock rotors before I got Rotora slotted rotors. I used my Rotoras for about 12K to 15K miles and never had a problem.
Old Aug 23, 2006 | 06:28 PM
My rotars went bad again? just 3 months? could it be defect rotar?
Old Aug 24, 2006 | 11:51 AM
RaviNJCLs's Avatar
It's quite possible. The stock rotors are crap. They warp really easily. It could be a defective rotor. You will have to get them checked. I once had one that cracked. Do a search on the stock brakes. You are not alone. And again, before you drop a lot of money on new stock rotors, I would say spend a bit more and get Rotora's. You won't be disappointed.
Old Aug 30, 2006 | 10:24 PM
BigLizard's Avatar
Moderator Alumnus
If your rotors have been machined once...and if its time to get them done again...go BBK or OEM sized slotted/cross drilled so they'll last longer. Yup the OEM rotors suck eggs
Old Sep 1, 2006 | 08:41 AM
bmehling's Avatar
how much is a set of rotoras?
Old Sep 1, 2006 | 10:19 AM
NSXNEXT's Avatar
There are some easy things to do to prevent warped rotors
1) Make sure the lug nuts on your wheels are torqued to 80lbs
2) Do not wash your car, especially the wheels immediately after a spirited drive - cold water on hot rotors =
Old Sep 8, 2006 | 07:35 AM
furious1smitul's Avatar
Terigan...
Have the same problems and I am positive it's not the rotors... I have a slightly bent wheel and the dealership "flipped?" the tire to balance it... Think that can be causing the vibration I feel on the wheel? Before they did the balance it was much less of a vibration and no steering shudder.
Old Sep 9, 2006 | 12:33 AM
celynka's Avatar
Sundance Gold in
UNFORTUNATELY VIBRATIONS WHILE BRAKING ARE 99% RELATED TO WARPED DISCS, NO OTHER COMPONENT CAN COUSE IT, IN SOME RARE CASES WORN BALL JOINT MAY ACT VERY SIMILAR. GOT SPORTY CAR GET YOURSELF VENTED QUALITY DISCS : BREMBOS ROTORAS OR STH, THEY RUN 200F COOLER THEN STOCK ONES. REMACHINING WILL SOLVE PROBLEM TEMPORARILY AS MATRIAL IS THINNER AND MORE LIKELY TO WARP.
Old Sep 11, 2006 | 10:36 AM
PhilB81's Avatar
A) they are rotors, not rotars,
B) I had the same problem, they machined mine, but next time this happens, it's up to brembos for me.
Old Sep 11, 2006 | 12:12 PM
Dron's Avatar
It's not just the rotors. Are you using aftermarket wheels? If so, then you definetly need a set of hubcentric rings which you can get online. This should definetly solve your problem!!!
Old Sep 11, 2006 | 12:31 PM
SIRSIG's Avatar
THE J35A2...
check for some loose bolts on your wheels meng.
i feel like a retord
Old Sep 12, 2006 | 09:57 AM
RaviNJCLs's Avatar
$300 or so with free shipping from www.streetbeatcustoms.com.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
