transmitter keyless
Old May 17, 2009 | 09:15 PM
canonoyp's Avatar
4th Gear
Cool transmitter keyless
i bought a transmitter keyless for my 2002 acura cl type s but the locking button is not working.any help is highly appreciated.thnx a lot.
Old May 18, 2009 | 02:11 AM
BAGII's Avatar
Well, if the rest of the buttons are working, but the lock button isn't, I would say it's a faulty transmitter. That will happen sometimes when you buy a used transmitter. But, if none of the buttons are working, it probably hasn't been programmed or it could have a dead battery.
Old May 20, 2009 | 09:26 PM
canonoyp's Avatar
4th Gear
guys anybody knows the steps in programming my transmitter keyless?my car is 2002 cl type s.again any help is greatly appreciated.
Old Jun 12, 2009 | 08:37 PM
F1refox's Avatar
6th Gear
1. Turn the ignition switch on (II on the ignition)
2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine)
3. W/in 1-4sec, turn the ignition switch off
4. W/in 1-4sec, turn the ignition switch on(II)
5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again.
6. W/in 1-4sec, turn the ign. switch off
7. W/in 4sec, turn the ignition switch On(II)
8. w/in 1-4sec, push the transmitter lock or unlock again.
9. w/in 4 sec, turn the ign off
10. w/in 4 sec, turn the ign ON
11. W/in 1-4, push the transmitter again
12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again.
13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and pull out the key.
15. Confirm proper operation with the new codes
Old Jun 27, 2009 | 10:55 PM
canonoyp's Avatar
4th Gear
thnx firefox.i have 2 transmitter keyless now that`s working.
tman570
Jun 11, 2019 07:56 AM
GraveDigger
Sep 18, 2015 07:46 AM
Sep 17, 2015 09:01 PM
JSuppi
Dec 3, 2003 05:12 PM
CL-Z
Jun 17, 2002 10:12 AM
