Transmission fluid flush, car surging
Old Apr 18, 2013 | 11:30 PM
lindasek's Avatar
3rd Gear
Hello everyone, I'm hoping to get some perspective. I bought a used 2003 acura cl type s from a small dealership around 5-6months ago and put around 6k miles on it since, maybe less (started off with mid 88k and have just hit 94k now), two days ago my car suddenly surged after unexpectedly slowing down - thinking it's the transsmission going I went straight to the dealer (perhaps 15-20 miles away), on the way there check engine light went up which scared me even more (I drove all the way to the dealer perhaps 20mi/hr just so the car wouldn't surge), the dealer took it overnight and in the morning told me that the transmission will need to be changed. Since together with the car I bought a cover plan (covering all non wear-and-tear things) they called the inspectors. The next day I got a call that after all they and my cover plan company recommend I do a transmission fluid flush since it doesn't look very well. I authorized it (since the cover plan won't pay such things) and came over to the dealer to ask why the change of heart. They told me that because the fluid was up for change, the cover plan will probably decline my claim to cover new/rebuild transmission even if the flush won't help. So! My question is, can they actually deny my claim? I have no idea if the original owner ever changed the fluid (I did only the recommended maintenance) plus I wouldn't even know where is the dip stick for transmission fluid so I never checked it. Will the flush actually help? I don't know the code for the check engine but was told it's something electrical that might or might not be damaged...
Old Apr 19, 2013 | 02:58 PM
LiveFive's Avatar
fluid change is always the cheapest route to go....but dont flush the transmission..only do a drain and fill. flushing causes more damage. you will need about 9 quarts in order to have fresh fluid. What does the fluid change and what was the CEL code ?
Old Apr 20, 2013 | 12:37 AM
lindasek's Avatar
3rd Gear
Well, it's already done, and since this is only a temporary fix not having the flush would cause the cover plan once again denying the need for rebuilding. The car drives pretty well now, there is a small delay between 2nd and 3rd gear but no surging, no noises or anything like that. I was told though that the fix is very temporary and the check engine light will come back on, if not in the next 1k then 5k. I've actually got the code of the shop and it's P0740 which is the torque converter clutch circuit malfunction, the mechanic still recommends the trans rebuild and proclaims his hate of inspectors. Also it turns out my car curiously doesn't have a trans fluid dipstick. But for now the car feels fine, I guess I will worry about it again once the car will start surging on me again
cobra10363
Jul 23, 2024 04:13 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
nanos
Nov 12, 2015 08:41 PM
Mike Bertram
Sep 10, 2015 09:27 AM
quake97
Aug 30, 2015 07:57 PM
