Took front seats out now SRS light is constantly on.
I decided to take out my seats to clean underneath them. I have dropped or spilled a lot of stuff down there and it seemed easier to just take them out. Well after I put them back in and connected all the wires again I get a big red SRS light on the dash just above the fuel gauge. It is solid red and won't go away. I checked all the connections to make sure they were secure and they are. Do I just need to reset the indicator light. I am sure there is nothing wrong with the srs system. Thanks.
Whats up with RDX owners?
Did you turn the ignition on while the seats were out? That usually trips it. You need to reset it.
Received 1,080 Likes
http://www.geocities.com/myintegra96/srs.html
I think you have to disconnect the battery to prevent the SRS light from coming on. See the instructions above for resetting it.
MP90 uninstalled
It just needs to be reset. I have done it several times. Its pretty easy. You make a jumper from the blank two pin plug that plugs into a blank socket under the driver kickpanel on the left side. Then turn ingition on (dont start motor) and do a series of connect circuit, disconnect circuit while toggling the ignition.
wham bam thank you ma'am
ALWAYS disconnect the battery when working around airbags or any other electrical systems, ALWAYS. If u get into an acciden with the srs light on. U won't have any airbags and I dought that the insurance company will cover any health bills bc u tampered with a safety device. U need to reset it like in the above link
Blown is Best
My SRS light came on recently and when they pulled the code on it, it pointed to a bad switch in the seat belt buckle so it was covered under warranty.
Just something to keep in mind if clearing the code doesn't resolve your issue.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
