Switchable later than 2G Autos
Old Aug 19, 2013 | 01:30 PM
Hamblaster's Avatar
4th Gear
I've read responses and threads from a couple/few dudes who moved ahead of the 2G automatics. Somebody went through 4 or 5 trannies? Can't the problem be FIXED by anyone? Anyhow, I'm not interested in it. I want to put a transmission in that has HAD the problems fixed by the engineers. Exactly WHICH transmissions can be traded out for my slipping/clunking/non-shifting CLS "01? I appreciate it. Lemme hear from first handers, pro AND con. TNX Hamblaster
Old Aug 19, 2013 | 02:35 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Just get a used06-07 Honda accord v6 transmission and swap it in. A bunch of us have done it to the tl without any problems
Old Aug 20, 2013 | 08:53 PM
ASpirational's Avatar
This. Finding a shop willing to do it was tougher than the job itself for me, and I only struck out once. That's really the only downside I've suffered.
As for specifics, 7G Accord (V6), 3G TL (non Type-S), and most 3G Odyssey transmissions will work. The latter may require tapping holes into the case, and I believe there's some late-builds that have different bellhousing patterns and thus won't mate. The first two are one in the same, so don't be afraid to ask for the 'Honda' unit if the salvager is charging a premium for its Acura counterpart. Below are the instructions I printed off for my shop since I still have that thread favorited.
Originally Posted by homeskillet43
These are the instructions my brother used when he converted my transmission back in March 2012. I am five thousand miles later, and the car drives, shifts, and runs great. I have never been a Honda fan, but this car is great. As you can see with the short amount of time and the large amount of miles driven. I recently took the car on a 2200 mile roadtrip it was amazing. Enough said about the tranny swap. Make sure to do all of the conversions when the trannies are side by side.
The entire trans oil heater assy, including the plate under the heater/cooler itself, and all of the brackets *don't forget a new gasket for the plate and anew trans filter* If the old trans has an oiljet kit installed, you will have to cut the t's out of it and fasten a new hose to both ends of the intermediate line.
The transmission range selector (otherwise known as 'neutral safety switch')will have to be swapped from the old trans, the newer switch has a different connector.
There is a small wire harness that connects to the 3 and 4 clutch pressures witches and the oil temp sensor, that will need to be swapped as well, theharness has a different connector to plug into the engine harness, but all theplugs going to the switches / sensors are the same.
You should not have to drill or tap anything, that's only with Odyssey transmissions, and very few at that.
I don't think the TL-S comes equipped with the power steering speed sensor, butif your's has it, it will need to be taken out of the picture... remove thehoses going to the rack, then loop a small hose point to point on the rackitself.
...... and that's it! Real simple, everything is direct bolt-on.
I used a tranny from an 06-07 Accord v6 auto trans listed as this:
A.T., Cpe (2 Dr), 3.0L (6 cyl)
MAKE SURE THE TRANS YOU BUY COMES WITH THE TORQUE CONVERTER, and if it DOSEN'Tget a NEW ONE!!!
DO NOT USE THE OLD ONE, YOU WILL DESTROY THE NEW TRANS!!!!
In the meantime, try to address any other questions via the search function. I'm not trying to be dismissive, but many of your potential questions have already been answered, and the members who are truly capable of going into detail aren't necessarily scouring the forums for threads like this.
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
