Stock HID bulb measurement?
metalguitarist.org
Did a search, found plenty of threads with the same problem I'm having (bad ballast/inverter or bulb) but I'm not sure on the stock size for the bulb. Are they 4300k HID?
Thanks!
Thanks!
metalguitarist.org
And while I'm at it (I swear, I searched), how the hell do you actually change just the bulb? I took a peek today to try and just swap the bulbs around to see if the inverter was the problem, and I don't even know where to begin.
I can see the fitting for the high beam obviously, but the low's behind some serious hardware. I understand I need to pull the bumper to change the electronics, but is it the same deal for just the bulb?
There's a security screw, so you'll need to either buy the tool (torx T25) or use a small screwdriver... turn the cover 45 degrees counterclockwise, same with the plug remove bulb....
https://acurazine.com/forums/showthr...headlight+bulb
Stock bulb is 4300K, but alot of people will just buy 'em in pairs so they match, or they buy a used one.
Definitely try to swap the bulbs first to see if it's just a bulb or if it's the inverter...
metalguitarist.org
Thanks man. In reading around here, I'm going to give the bulb swap a try tomorrow and cross my fingers. The bulb lit up for a day or so and flickered, but last night it turned on this insanely purple color then just poofed.
Otherwise, I have the bumper removal how to from here already printed out, and a case of beer in the fridge in case things go sour. I even ordered a new set of bumper clips, since I'm sure I'll break pretty much all of the damn things taking it off.
Here's a picture of the headlight to give you an idea of what's in there...
#2 is the screw, then you've got to twist #12...
If you don't have a helms manual the online OEM parts places have some nice pics to look at
I stole the pic from http://www.acuraautomotiveparts.org
