So how easy is it to cut....
Old Jan 3, 2012 | 06:01 PM
Seymore Cake's Avatar
'01 Acura CL Type-S
So a few weeks back I was in a car accident which resulted in moderate front end damage and everything was fixed but they tossed my LED fog lights
So I ordered a new set that contained 18 LED's vs the 12 or 15 prior to these
Now the problem is these new LED bulbs are about 1 1/2 times the size of the ones before....
So my question is how easy is it to properly cut the fog light hole to a slightly bigger hole?
Are the fog light housings easy to remove?
Old Jan 4, 2012 | 12:49 PM
civicdrivr's Avatar
I assume you meant the bulb hole in the OEM road lamps?
Just use a file and take a little off at a time.
To removing the housings, there is one screw on that you can access through the grille in the bumper. Unfasten that, then they slide out.
Old Jan 9, 2012 | 02:21 AM
'01 Acura CL Type-S
Yea I found a write up on that the other day, but I didn't think about using a file, thanks will try it on a warm day
tsx_boy
Dec 13, 2019 08:33 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
h22lude
Sep 27, 2015 06:22 PM
