Small question that I couldn't find @ faq+stickies...
Hi people~ newbie here!~
I was reading through the forums and searching in this forum, as well as google...but couldn't find the answer to this question!!
How similar are 2G TL's and CL's?
I hear that they are very similar, and that you can use the DIY's for the TL's for installing parts for CL.
However, are the parts compatible with each other? like...
If I had an intake or suspensions for the 2G TL-s, would that fit the 2G CL-S?
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Yes all the parts off a 2g tl/cl and 99-2002 accord v6 r da same.
My BG suspention kit said V6 accord on it and I installed Headers OBX that where on a 2001 V6 accord on to my 2001 CL today. I say 90% of the aftermarket parts are the same on both cars!
most parts will swap .. my 98 AV6 has my '01 cls' rear sway my koni suspension my front rotora breaks and calipers ... and maybe soon some of these guys' that are swapping to the '09 upper intake will sell me there org. and ill add that along with a apexi to trigger the IMRC
Whats up with RDX owners?
The TL rear doors wont fit on the CL.
5 minute rule
All suspension from 6th Gen Accord is the same.
Most parts are identical...you really only run into differences on cosmetic items (front end, rear end, door dimensions and piping for exhaust)
Basically that's the only real differences.
They are interchangeable between 2nd Gen CL, TL, and 6th Gen Accord.
The motors in the TL-P and the CL-P are the same, as with the Type S' (J32A1 for the Premium models, A2 for the S').
BUT there are differences between the automatic J32A2 and the manual J32A2, cam gears are different if I recall correctly.
Ok:
Timing Belt Pulley
Part #s:
- 13621-P8A-A01 (auto)
- 13621-PGE-A11 (6MT)
![](https://i733.photobucket.com/albums/ww337/danjerusmoke/img0001medium8vi.jpg)
Cam Gears:
The front cam gear is different between the auto and manual. The manual cam gear has PGE stamped on it.
Part #s:
- 14260-P8A-A01 (auto)
- 14260-PGE-A11 (6MT)
Timing Belt Pulley
Part #s:
Cam Gears:
Part #s:
![](https://i733.photobucket.com/albums/ww337/danjerusmoke/img0001medium9rk.jpg)
The sensor plugs? No, those are different.
If you were swapping this engine into a Civic or something and you used an Auto harness on a 6MT engine, youd need to get the sub-harnesses for the two sensors.
GODDAMN, I just checked prices on the sparkplugs for this car. $10 each ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
NGK IZFR6K11 for the 6MT
Not including shipping though. They are $13 at the dealer. I hate 6 cylinders. I cant get plugs in packs of four
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
