Shaking when braking
Old Jun 13, 2016 | 11:44 AM
tabb22's Avatar
I replaced rotors and brakes still get shaking when braking. Do you think alignment will help
Old Jun 18, 2016 | 11:38 PM
03 tls nc's Avatar
Doubt full. What brand rotors and pads did you use? Did you check the run-out on the rotors when you installed them?
Old Jun 19, 2016 | 09:37 AM
AMSCLS's Avatar
Common things to check is the rotors place correctly, pads seated right, tire pressure even, lug nuts tighten to OEM spec. After that one caliper piston could be sticking.
Old Sep 9, 2016 | 06:41 AM
DanFnRight's Avatar
3rd Gear
I've had the same problem for years... It seems to come and go.
My old mechanic told me I had "exceptionally rusty rotors" that were likely causing the issue (but that it was nothing really to worry about). But if you've already tried this without success, any info that you find would be helpful; I'll report back if I find anything.
Old Sep 9, 2016 | 06:42 AM
team shake and brake!
Ian.van
2G TSX Problems & Fixes
Jun 30, 2020 11:58 AM
ahung
May 18, 2016 01:37 PM
rudycat
May 16, 2016 02:44 PM
jmzb1002
Apr 5, 2016 08:47 PM
nickmye
Jan 27, 2016 09:56 PM
