screetching noise, help
i havent driven my car in a couple of days and now there is a screetching or grinding noise coming from the front tires, i just put h-tech spings in a week ago. my guess is it is my axles but im not sure
Originally Posted by brianlin87
my guess is a faulty installation of the springs and something has come loose.
i would take it back to the tech that did the install and have him give it a once over. the camber kit(s) is a good investment becasue it will save you $$$$ on tires in the long run. when lowering a car it will give your tires a negative camber, so when you drive, you are wearing the inside of the tires faster then normal. not sure if you have custom wheels, but performance tires for aftermarket wheels are loot $$$$$ . if you dont have camber kits installed check out this link for a set of front/rear kits:
http://www.autocarparts.com
http://www.ultrarev.com/manufacturer...ufacturerid=34
i recommend the adjustable control arms for both front and back, as it gives your tire camber full adjustability.
let us know what the tech says about the install and if he figures out just what the hell is going on. good luck!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
