RPM high
RPM high
Hi all, I wonder if someone can help me with this problem?
I donīt nkow if thie a new thread or not. but, just please can anyone help me out with this issue?
2003 Acura CL base type . When I use the car for a moment, power and rpm is normal. but when the enviroment temperature rises to 70 degrees rpm goes up to 1500 rpm using the brakes at any traffic light and make your changes progressing normally 1,2,3rd an so on...and when i park the car goes up to 2500 rpm.
Sometime i have to use the water hose,,, i have verified the EGR valve and now that i toke it to Autozone they told me that i have to change the MAP sensor.
as always appreciate your help and thanks in advance to whoever helps me. thanks for solidarity assume
The only codes that iīm having is for the MAP senor, iīll pick that up today and see if that is the issue, iīll keep you posted, couse tha problem that im having it looks the same to others. But, i donīt know until i put the MAP sensor, iīll let you know whats going on today.
Thank you for taking the time and help me!!!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
