Right turn signal bulb works but does not blink when turning
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Hey guys, im facing this problem and hoping someone might help,
The right signal bulb works when i turn the general light switch on but when i try to switch the turn signal it does not blink and on the dash it blinks fast like it does when the bulb is fried
I am so confused i hope someone might be able to help
PVP01CL-P (08-18-2016)
Appreciate your help, i checked the bulb 3 times with a brand new one, didn't work, relays are fine, then out of no where i checked the same bulb again and it worked, don't know how that happened but am glad it did
The signal wire to the bulb is loose somehow. Those bulbs are dual filament and if you look at the pigtail, that are three wires: parking, signal, and ground. Check the wires
