Rear Main Seal
Old Jul 11, 2006 | 11:54 AM
JEFF88's Avatar
Rear Main Seal
rear main seal is leaking. any insight from someone who has done it on this car would be nice. 03 cl-s 6spd.
Old Jul 11, 2006 | 01:54 PM
Moodist's Avatar
You need to take it to the dealer and see if it can be done under warranty. Also, there is a slight chance that the leaking oil got on the clutch and flywheel, it may need to be replaced. Do a search, a couple of people have had the same issue.
Old Jul 11, 2006 | 04:00 PM
JEFF88's Avatar
no more warranty due to miles, but i was thinking about the clutch and flywheel. ill def. look into it. thanks bro
Old Jul 11, 2006 | 06:00 PM
fuzzy02CLS's Avatar
How many miles on it?
Old Jul 11, 2006 | 08:27 PM
GreenMonster's Avatar
Some other people w/ 6spds have reported this...
I've got 49.6K miles so my warranty is up... I checked for leaks before I brought her in for the 45K service...
mc_yanzo thought he had a rear main seal problem....
https://acurazine.com/forums/showthread.php?t=169394
but it ended up being something else tho'....
https://acurazine.com/forums/showthread.php?t=170770
Old Jul 11, 2006 | 10:01 PM
Allout's Avatar
Blown is Best
I had mine done under warranty at around 27K. Since it was open, I upgraded to a Comptech Flywheel and replaced the pressure plate with a new stock one. Make sure your PVC valve is clean to avoid any excess crankcase pressure from building up. I think it's about $800 in labor to swap out the $10 seal. From what I understand, changing the rear main seal is part of the procedure when replacing a clutch nowdays.
If you're thinking of replacing your clutch at the same time which is a good idea to do, Competition Clutch may have something for us in the next few months as an alternative.
https://acurazine.com/forums/showthread.php?t=181700
BTW - I'm at 52K miles and I've got a new leak. I first thought that it was the rear main again but it turns out that it's on the gearbox side - probably on the input shaft. You may want to change that seal also if they're in there.
Old Jul 12, 2006 | 07:55 AM
JEFF88's Avatar
mine has 80k miles. thanks for eveyones comments, ill let everyone know when i do it.
thegipper
Oct 21, 2015 07:19 AM
IIDXholic
Oct 8, 2015 07:53 AM
Sep 21, 2015 08:44 AM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
