problems with clutch need help please
Old Dec 30, 2009 | 04:03 PM
darwinsalguero1991's Avatar
6th Gear
hi every1, any help will be thanksful,, this is my story i m going to buy a honda civic 99 120xxx miles ,,, but there is a little problem on the car The clutch does make a little ticking noise. i was told that the clutch release bearing is loose, is this a big problem? should i buy this car,, ,,,,,could the noise be something really bad? please help
Old Dec 30, 2009 | 04:05 PM
6th Gear
help please
Old Dec 31, 2009 | 05:00 PM
celynka's Avatar
Sundance Gold in
Originally Posted by darwinsalguero1991
help please
if it is release bearing issue, you will need entire clutch job, however it may not fail totally for another 2 years. Definately use this as an levrage in negotiating price
Old Jan 6, 2010 | 02:55 PM
iggie's Avatar
I agree with celynka.
you will need an entire clutch job to fix it but it might hold for another 2 years.
i had the same problem on my car and once i got my clutch replaced with a new release bearing, no more ticking noise
but the ticking noise stops when you press the clutch right?
Old Jan 6, 2010 | 07:24 PM
6th Gear
yeah, iggie, the ticking stops when i press the clutch right.. ,, thank you guys, ,, ill buy that car i like it anyways
SidhuSaaB
May 30, 2020 12:40 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
rboller
Sep 23, 2015 02:49 PM
