power steering fluid replacement
03 Acura CL Type S 6 spd
Does $90 sound reasonable to replace. Acura dealer says power steering fluid is dirty and that it will cost $90 to replace. Should I call around Minneapolis MN for quotes? If I do go to someone else, is Honda power steering fluid required?
Do it your self. Really easy. Use Honda or Acura power steering fluid.
All you have to do is un bolt the hose at the reservoir, & drain it into a pan or cup or whatever. Start engine & turn the steering wheel lock to lock 2 times.
Connect hose back & refill the reservoir.
If you wanted you don't have to turn the steering wheel. Just pull the hose & drain the fluid, then refill it & drive. Won't get all the old fluid out but it 's close.
Dealer price sounds right. They are a dealer, & are expensive.
mada51589
05-03-2022 08:54 PM
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
